05-23-2020 04:47 PM
06-01-2020 01:16 AM
06-03-2020 11:38 PM
gbunThank you 🙂Hi team,
I updated to max pro m2 with latest .424 build of android 10 beta and i see the bugs please asus fix this bugs and give the next ota fast. Bugs in max pro m2 I,m facing which is given below
- slow charging:- when i plug the phone with original charger of asus then after 5 min it showing rapid charging after half an hour after that it showing charging which charge the phone with normal speed after 5 to 10 minutes its showing slowly charging and it takes more time to charge generally it occurs (slowly charging) after 40 percent of charging. This is the serious issue I'll facing.
- round corner is missing in the bottom edges
- ringing and notification sound is low
- in speaker there is no bass and sound is also very low and in pie build it is ok
- and the suggestion from setting is not removing
- notification light blinks sometimes green sometimes yellowish white
max pro m2 beta 2 bugs
06-04-2020 05:45 AM
Y_ASUSZB602KL 6GB varient.Hi parvezalam01994,
Is your phone ZB601KL or ZB630KL?
Please provide your firmware version: Settings > About phone > Build number.
For ZB601KL, this issue is under investigation. Thank you 🙂
07-09-2020 12:21 AM
salman64867The latest Android 10 version WW-17.2017.2006.429 has been released.Even I hv heard that the HD graphics has been disabled in AOSP BETA 2, so please make it come again.
Please add ultra fps in low graphics in Pubg.
