09-03-2020 02:19 AM - last edited on 01-16-2024 12:40 AM by ZenBot
09-03-2020 07:35 PM
09-27-2020 08:54 PM
09-28-2020 09:16 AM
Christine_ASUSi got the same issue. My phone got stuck at logo after the update in june. I emailed my complaint again and again to the company after which i got my motherboard replaced by the company almost after a month. They did not update the firmware when they replaced it. As you see, an update caused all of it so i was afraid to update it again. but the annoying notification forced me to update, 3 days ago. and nowwww as expected from the company, my phone is again stuck at the logo. Recovery mode opens up 1/100 times of rebooting. factory reset gives 1 hour of no problems. and then again it froze like brick and when forced restart, bootlooping occursHi kulsoom
Thank you for your asking. Kindly provide the information below so that we can better assist you.
A. Does the issue appear after any system/apps' download or update?
B. What do you mean your screen is not working? Can you provide me any video to clarify the question?
C. Please try the following steps to access recovery mode for the Factory Reset:
0. Try to back up your data with USB cable. If you can not access the phone, please check if your google account or microSD card have auto backup your data.
1. Power off the phone, then keep pressing "volume down key"
2. Press "power key" and stop press " power key" once you feel the vibration. Still keep pressing "volume down key"
3. Stop press "volume down key" once you enter [Android Recovery] Screen
4. Choose "Wipe data/factory reset">"Factory data reset"
5. "Reboot system now"
#Hardware Reset Guide
https://www.asus.com/support/FAQ/1006346/
Please note that once the steps are completed, all data, apps, settings and personal information will be deleted.
10-01-2020 09:09 PM
