05-06-2020 09:53 AM - last edited on 01-16-2024 01:16 AM by ZenBot
05-06-2020 05:24 PM
05-06-2020 09:13 PM
rohitashva.dongre86I am also facing the same problem in the build version of .063. Battery drain issue it at extreme. Idle battery drain is almost upto 12% in an hour. Screen on time is also reduced upto 2.5 hours only. Phone is also heating a lot. I uninstalled all the unnecessary apps. But nothing worked. I just hope that android 10 update will solve these issues.
reddynikhil2000What is the temperature of your phones?? Don't blindly say over heating. As the device has metal back, you'll feel 2-3 degrees higher than original one.Please tell us some basic information before asking for help:
- Model Name:
- Firmware Version:
- Rooted or not:
- Frequency of Occurrence:
- APP Name & APP Version (If your issue relates to the app):
Max pro M1
Phone up to date
Not Rooted
Over heating. And immediate battery drainage while phone is switched OFF. what to do??
05-07-2020 06:18 PM
manojreddy.budatiI have been using the phone since last 2 years and I never felt the phone heating this much. Even I use the phone in battery saver mode all the time and I don't play any game too. I also use Greenify app that automatically kills any background apps. Inspite of doing all this, my phone is heating a lot and battery backup is all time low now after this last update.. Asus has ruined the experience. I need to charge my phone 3 times a day during this lock down period.https://zentalk.asus.com/en/discussion/comment/77923#Comment_77923
05-13-2020 08:40 AM
