10-17-2020 11:02 AM - last edited on 01-16-2024 01:06 AM by ZenBot
01-19-2023 06:38 AM
1. Go to Settings->Apps
2. Show System Apps
3. Disable that f**king ZenUI Safeguard.
Worked for me...
11-14-2020 01:29 AM
veeharish2005It is indeed a Feature if user intends to call an emergency.https://zentalk.asus.com/en/discussion/comment/132368#Comment_132368
1. This feature is a requirement if they want to sell the device in the country according to my knowledge.
2. My old lenovo, lg and my nokia 8.1 ,6.1plus also does the same.
https://zentalk.asus.com/en/discussion/comment/132792#Comment_132792
It is not a bug.
11-14-2020 01:40 AM
VralWhich version is your device in bro ?https://zentalk.asus.com/en/discussion/comment/132822#Comment_132822
But if it accidentally calling the emergency number without users knowledge, its a bug. By what I described, I think its clear that its a bug.
11-14-2020 03:14 PM
nidhin3Latest and greatest firmware from Asus. Regarding reset, I think that should be the last step one shall resort to. A bug free software means, end user should have a seamless experience.https://zentalk.asus.com/en/discussion/comment/132851#Comment_132851
I think its happening only in your device. Well, I did not encounter this issue while unlocking via fingerprint scanner. I believe that is the case with majority of users here. Try to Reset your device. If that is not working it might be a hardware issue.
11-14-2020 05:20 PM
VralYou mean you are in Android 10 beta 4 ?https://zentalk.asus.com/en/discussion/comment/132852#Comment_132852
Thats the whole point. Its a bug.
