Off emergency call press in power button
kru6070
Model Name: Asus zenfone M2 Pro
Firmware Version:
Rooted or not:not
Frequency of Occurrence:
APP Name & APP Version (I usef your issue relates to the app):
24 REPLIES 24
1. Go to Settings->Apps
2. Show System Apps
3. Disable that f**king ZenUI Safeguard.
Worked for me...
Vral
veeharish2005
https://zentalk.asus.com/en/discussion/comment/132368#Comment_132368
1. This feature is a requirement if they want to sell the device in the country according to my knowledge.
2. My old lenovo, lg and my nokia 8.1 ,6.1plus also does the same.
https://zentalk.asus.com/en/discussion/comment/132792#Comment_132792
It is not a bug.
It is indeed a Feature if user intends to call an emergency.
But if it accidentally calling the emergency number without users knowledge, its a bug. By what I described, I think its clear that its a bug.
nidhin3
Zen Master I
Vral
https://zentalk.asus.com/en/discussion/comment/132822#Comment_132822
Which version is your device in bro ?
I think its happening only in your device. Well, I did not encounter this issue while unlocking via fingerprint scanner. I believe that is the case with majority of users here. Try to Reset your device. If that is not working it might be a hardware issue.
Vral
nidhin3
https://zentalk.asus.com/en/discussion/comment/132851#Comment_132851
Latest and greatest firmware from Asus. Regarding reset, I think that should be the last step one shall resort to. A bug free software means, end user should have a seamless experience.
Thats the whole point. Its a bug.
nidhin3
Zen Master I
Vral
https://zentalk.asus.com/en/discussion/comment/132852#Comment_132852
You mean you are in Android 10 beta 4 ?
