Notification sound
brucebanis
ZF Model: ZB602KL
RAM: 6G
Firmware/APP Version: 16.2017.1908.058
Frequency of Occurrence: Permanent
Rooted: No
APP Name: Notifications
Hi all,I bought an Asus Zenfone Max Pro M1 and I noticed that there is no way to change notification sound for any app unless they have a bulit it option to do so. For Example There is no way to change the incoming message tone for Instagram. But Whatsapp message or calls notitfication can be change as it has the option in the app itself. Preciously on my other phone I could touch an hold on any noitification and change its sound or even assign a different LED color. Is there any way to be change these settings? Thank you!
brucebanis
Well, I guess I found the answer myself. It is possible to set notification for any apps on my phone!
