My ASUS max Pro m1 which gets freezer when ever I receive or call someone until call ends
ramm_1263
Model Name: Max pro M1
Firmware Version:
Rooted or not: not rooted
Frequency of Occurrence: everytime
Yachendra
Rising Star II
ramm.1263
  1. Model Name: Max pro M1
  2. Firmware Version:
  3. Rooted or not: not rooted
  4. Frequency of Occurrence: everytime
Freeze means how, is screen getting turnedoff while call or screen is on and non responsive?
-->If screen turned off then it might be due to bad proximity sensor: Check whether proximity sensor is covered with any dust/screen guard.
If, you applied screen guard recently and facing this, remove it and check.
-->If screen is non responsive: Try clear data of the phone app and check. If not working, try reset device.
If in both cases not working, then visit nearest Asus service centre to get device checked by expert.
ramm_1263
Non responsive of screen.. done hard reset... But still problem exists
victor010
Zen Master III
Hi, we suggest you to please visit the nearest ASUS service center for better assistance. Locate here : https://www.asus.com/in/support/Service-Center/India
