08-14-2020
06:08 AM
- last edited on
01-16-2024
12:46 AM
by
ZenBot
08-17-2020 04:54 AM
09-12-2020 09:13 AM
Victor01_ASUSLatest version is 084Hi there, kindly let us know the firmware version your device is on.
Also, there can be multiple things which may cause this issue, try the below troubleshooting:
1. Check if there isn't any third party app which might have caused the device to slow down
2. Your device should have a few % of storage left as less free space on the device can cause a device to run slow
3. Ram management - there should always be adequate RAM available if the device needs to work flawlessly
4. Restart whenever you face this issue
5. Restart the device in safe mode – i. Power button hold for 2 seconds, ii. tap on the power off message which pops up on the screen, hold for few seconds it will give you an option to boot in safe mode.
6. Also, check if your device is on the latest software version.
7. If nothing work you can back up your phone & factory reset your device : https://www.asus.com/support/FAQ/1006346/
09-12-2020 11:11 AM
AJ1The latest version is .087https://zentalk.asus.com/en/discussion/comment/104138#Comment_104138
09-13-2020 01:42 AM
veeharish2005Didn't recd that update notification on my devicehttps://zentalk.asus.com/en/discussion/comment/112180#Comment_112180
