Mic issue while playing Pubg (Zenfone Max Pro M1)
dibyarupprk2011
Rising Star II
Model Name: Zenfone Max Pro M1
Firmware Version: .082
Rooted or not: Not Rooted
Frequency of Occurrence: Every time
APP Name & APP Version (If your issue relates to the app): PUBG Mobile
In .082 update, while playing Pubg the microphone doesn't work , when I switch on the microphone in Pubg it does switch on but other team mates can't listen to me and tapping the volume buttons it shows the in call volume panel with media volume whereas the in call volume panel should not be seen.
COMMENT IF YOU PEOPLE TOO FACE THIS OR SOME FIX.
victor010
Zen Master III
Hi there, kindly check the microphone of the device if it is working fine or if there is any issue with it, also check if you have enabled all required parameters in PUBG under Audio option and see if the issue is there.
