(MaxProM1)(v432) Gcam Stability Discussion
RadeonPS
Rising Star II
#Moderators do note this is for discussion among users and Gcam ports are not officially supported is acknowledged.
Rose in Zenfone Max Pro M1 Gcamthe_dise: DMGC_7.3.020_ver.4.5.apkBeta5 suggested stable gcam doesn't always capture images.
Do suggest any workarounds if any?
Anyone on stock a10 beta5 using a more stable Gcam?
DMGC vers4.5 samples
12 REPLIES 12
abhaykrishnan02
Zen Master I
Anandu
https://t.me/X00TDGCAM/22118
https://www.celsoazevedo.com/files/android/google-camera/f/changelog1227/
Try g-cam go version
I prefer g-cam only for its night mode photography
RadeonPS
Rising Star II
abhaykrishnan02
https://zentalk.asus.com/en/discussion/40785/maxprom1-v432-gcam-stability-discussion
https://us.v-cdn.net/6031231/uploads/9QCINVKGE77F/camerago.apk
Gcam Go has terrible image processing. Instant translate mode is the only good thing.
DMGC is far better in image processing.
Compare portrait selfies between both to see the difference
RadeonPS
Rising Star II
Is this "camera calibration" app required? Since something is interfering with the Gcam in A10v432. Pie build always had Gcams stable.
V432 has all the Gcams sometimes non responsive during Capture and requires restart.
nidhin3
Zen Master I
Anandu
Ya, Gcam on max pro m1 running on Android 10 is having some issues.
Try this. This one is working for me (Not with 100% accuracy) Some glitches are there. Still, by far the stable one I could find
https://t.me/ZenfonePhotography/164805
If you have one more stable, do share that.
