09-27-2020 03:28 AM
09-28-2020 11:55 AM
09-28-2020 06:19 PM
09-28-2020 10:35 PM
09-28-2020 11:25 PM
rumputliar30You should definitely give adb uninstallation of icepower a try.I have some problem with Android 10 beta build 432.
Bugs report:
- Sound audio via headset drop if i play music player and open youtube web together.
- Sound quality via headset little bit sibilance.
- Please improve sound quality,i am feel something wrong with this audio quality. Because i am listen music everyday.
- This update change audio codec from 24bit to 32 bit. 32 bit Hi-Res audio codec not support for Poweramp.output volume very low and flat sound.please change to 24 bit/48khz.
- Sound volume not increased from 70% to 100%. Please fix this bugs for next update.
- Camera can't capture RAW photos.
Max pro m1 ZB602KL: Audio bugs output, Android 10 beta build 432
