[Max Pro M1 ZB602KL] (A10 V424) Bass Disappear/PUBG HD/Call of Duty HD
uspenskiy_ua
Model Name:ZB602KL
Firmware Version:QKQ1.WW_Phone-17.2017.1911.407-20191223
Rooted or not:No
Frequency of Occurrence:Constant
I would like to report a bug that removes bass from sound. Steps to reproduce it:
Every time i reboot phone and instantly (as fast as i can) start playing music - sound quality is perfect with full bass. After approximately five seconds of playing music - bass suddenly disappears, sound quality drops. Moreover it behaves the same for both bluetooth and jack audio.
It seems as if some additional equalizer settings are applied later in boot process - but i don't have any equalizer app installed on my phone.
Steps i took to resolve the issue:
Reset app settings
Tried safe mode - but there is no music player so doesn't count
Reset to factory settings
Therefore I would like to record and submit logs from my phone and fill a bug - can you please advise how can i do that.
Thank you in advance for your help.
38 REPLIES 38
tjcomp_rocker
uspenskiy.ua
https://zentalk.asus.com/en/discussion/comment/76097#Comment_76097
this is definitely a software bug that is related to sound output not through built-in speakers but through headphones - therefore proposed solution would not help with this issue.
Okay......my loud speaker volume was very low even with stock oreo firmware and some popular custom roms......so I concluded that issue must be to do with hardware hence I suggested this.......
if you know how to unlock bootloader and flash a custom recovery I would suggest to try flashing stock oreo firmware and check if it solves the issue.........that would be the quickest solution......provided you already know how to unlock bootloader etc.
uspenskiy_ua
tjcomp.rocker
https://zentalk.asus.com/en/discussion/comment/76297#Comment_76297
the latest 424 update description mentions fixing low frequency sound issue - I guess I am going to wait for that update
Christine_ASUS
Community Legend II
Hi uspenskiy.ua,
A new firmware update version WW-17.2017.2004.424 has been released. We have improved the sound issue.
You may manually download it from our website: https://www.asus.com/supportonly/ZenFone%20Max%20Pro(M1)(ZB602KL)/HelpDesk_BIOS/
How to update firmware: https://www.asus.com/support/FAQ/1009748/
Please make sure to back up your data before updating.
uspenskiy_ua
Christine_ASUS
Hi uspenskiy.ua,
Hi @Christine_ASUS ,
appreciate your providing update on that. I tried downloading and updating my firmware manually - unfortunately it didn't work.
I have Global version of ZB602KL Zenfone Max Pro M1 phone and I used indian version of Android 10 beta to update my firmware to WW-17.2017.2004.407.
Can you please advise if there is any way for me to update my firmware to global version from currently being on indian WW-17.2017.2004.407 ?
Christine_ASUS
Community Legend II
Hi uspenskiy.ua,
To make it clear, you would like to upgrade from WW-17.2017.1911.407 to WW-17.2017.2004.424, right?
Have you tried upgrading "manually" to this version but it failed?
If yes, compare to the "Manual Update" guide in "How to update firmware" I provided before, could you tell me the issue detail and the steps you perform? Have you facing any unexpected password key message, or have you receive any error message?
Also, please check your inbox for a PM I've sent you.
