04-21-2020
05:15 PM
- last edited on
01-16-2024
12:58 AM
by
ZenBot
05-12-2020 03:18 AM
05-17-2020 06:38 AM
05-21-2020 11:13 PM
05-22-2020 06:29 AM
Christine_ASUSCan u please fix the bass issue it was fine in Android 9 but in the 424 update just ruined it.Hi all
I have forwarded the issue of Bass to the relevant department. We will keep you updated and your consideration will be very much appreciated.
Thank you for your continued support and patronage.
05-27-2020 10:15 PM
Christine_ASUSHello @Christine_ASUS ,Hi Supertambov,
Furthermore,
>PUBG/Call of Duty HD
I have forwarded the information to the relevant department. We will keep you updated and your consideration will be very much appreciated.
>Battery
Do you mean battery draining? It happens in idle mode or using (which apps or functions?)
>Bad sound when calling
Is the quality worse compared to Version P? Using what kind of device(cable or blue tooth)? Any audio calling app or preloaded app?
