max pro m1 beta 4 432 update>No network strength icon
Ghostrish26
【Version】
17.2018.2008.432
【Model Name】
ZenFone Max Pro (M1) ZB602KL
New bug added after 432 update.
1. No network strength is showing on notification panel only showing volte logo.
23 REPLIES 23
Astar
Volume isn't increasing or decreasing by holding volume up or down button.
Astar
I'm using two different wallpaper in my home and lock screen . When i unlock my phone i see my lock screen wallpaper in my status bar for 1 sec.
lordabhi18
Did u face password problem while updating to 432
Christine_ASUS
Community Legend II
Hi Ghostrish26
Thank you for your asking. My MPM1 with A10 V432 has the icon of network strength. Kindly provide the information below so that we can better assist you.
1. Please try to enter "Safe Mode". If the function works well in Safe Mode yet the issue remains out of Safe Mode, please check on any disturbance from the installed 3rd party apps.
2. Also, please try "the Factory Reset"
Settings>System>Advanced>Reset options>Erase all data(factory reset)
Please note that once the Factory Reset is completed, all data, apps, settings and personal information will be deleted.
If the issue persists, please do not hesitate to report in this thread.
Christine_ASUS
Community Legend II
For other issue, please open their own threads for each issue. Please do SEARCH the first page to check if there is the thread of the same issue.
