Manually Update to firmware 0.58
danneyladero
ZF Model: ZB602KL
RAM: 3G
Firmware/APP Version: 0.58
Frequency of Occurrence: STABLE PIE 9
Rooted: No
APP Name: New updated
New Update 0.58(148mb) 1.DRM back to L1 again 2. Battery Optimization is good 3. Charging Fast 2 n half hour 4. Sound good n loud even using Bluetooth device 5. Gaming experience good 6. They didn't fix 4G n battery icon 6. Finggerprint fast 7. Faceunlock is fast 8. Security patch still August
Hardididin
Do you have issue with SD card. Mine SD won't detect 128Gb lower than 32Gb, ok ... :( Did anyone facing the same problem ... any suggestion?
