07-20-2020
04:58 AM
- last edited on
01-16-2024
12:54 AM
by
ZenBot
Admin【Version】
16.2017.2007.094
【Model Name】
ZenFone Max Pro(M2) ZB630KL
【Release Date】
2020/07/20
Since the server pushes update notice to different serial numbers by batches, it may take some days for you to receive the FOTA notice. Thanks for your patience. You may tap “System updates” in [Settings] >[System] to check if there is new firmware available. Or, you can also try to manually update firmware by referring to the following link.
How to update firmware on my phone?
【Release Note】
- Updated Android security patch
- Fixed SIM card name editing issue
[200720] ZenFone Max Pro(M2) ZB630KL_IN_16.2017.2007.094
AdminIf you have received the update please share the experience and battery life with this update.【Version】
16.2017.2007.084
【Model Name】
ZenFone Max Pro (M1) ZB602KL
【Release Date】
2020/07/20
【Release Note】
[200709] ZenFone Max Pro (M1) ZB602KL_WW_16.2017.2007.084
07-20-2020 11:32 AM
07-20-2020 11:41 AM
veeharish2005Can you share the ss of the website where it's mentioned as 084 updateThe .084 update file for asus zenfone max pro m1 from the asus website is corrupted.
When I tap on the download button on the website ,it only downloads a 4mb zip file which is currupted.
Can you guys fix this issue?
07-20-2020 11:47 AM
dibyarupprk2011https://zentalk.asus.com/en/discussion/comment/98004#Comment_98004
07-20-2020 08:20 PM
07-20-2020 08:25 PM
