07-20-2020 04:58 AM - last edited on 01-16-2024 12:54 AM by ZenBot
Admin【Version】
16.2017.2007.094
【Model Name】
ZenFone Max Pro(M2) ZB630KL
【Release Date】
2020/07/20
Since the server pushes update notice to different serial numbers by batches, it may take some days for you to receive the FOTA notice. Thanks for your patience. You may tap “System updates” in [Settings] >[System] to check if there is new firmware available. Or, you can also try to manually update firmware by referring to the following link.
How to update firmware on my phone?
【Release Note】
- Updated Android security patch
- Fixed SIM card name editing issue
[200720] ZenFone Max Pro(M2) ZB630KL_IN_16.2017.2007.094
AdminIf you have received the update please share the experience and battery life with this update.【Version】
16.2017.2007.084
【Model Name】
ZenFone Max Pro (M1) ZB602KL
【Release Date】
2020/07/20
【Release Note】
[200709] ZenFone Max Pro (M1) ZB602KL_WW_16.2017.2007.084
07-27-2020 10:29 AM
07-28-2020 05:05 AM
chandan.attuluriI don't have that problem in my phone so try clearing the cache and storage of pubg in the settings.I'm facing Issue while Opening PUBG MOBILE after updating the phone to July Security Patch Update. The Application is crashing while opening. Can you help me resolve this ?
07-29-2020 08:53 AM
07-30-2020 09:33 PM
08-09-2020 10:48 PM
