Issue of Beta 2 (424)
souvikshaw4004
Model Name:asus max pro m1
Firmware Version: 424
Rooted or not: not
Frequency of Occurrence:
I have updated android 10 version 424 via manual update which is provided on asus max pro m1 firmware page.
1.Unable to remove suggestions on settings
2.Most Important VOLTE issue on Vodafone
3.Charging time is same
4.The speaker and earphones output is low.
5.Network fluctuations issue and very low graphics with PUBG
6.Sometimes Wifi toggle shows connected on notification panel but when i drag notification panel it shows as not connected
7.Unable to move Google widget on home screen
8.Picture in Picture mode doesn't work properly
9.Call recording is not working
10.Forced Dark Mode doesn't worked well with Facebook and some others app
There are some bug fixes too in version 424
1.The UI experience is very smooth, there are no lag in UI.
2.There is no menu bugs in android 10 compared to pie
3.Wifi calling is enabled for jio
4.Camera2api is enabled
victor010
Zen Master III
Hi there, thank you for highlighting the issue. We have made a note of the feedback and will share it with the relevant team.
