Hi
a.m.plabonThank you for your asking. To perform the Factory Reset supposes to be the same thing of what you required, and it is easier! Please try "the Factory Reset"
Settings>System>Advanced>Reset options>Erase all data(factory reset)
Please note that once the Factory Reset is completed, all data, apps, settings and personal information will be deleted.
p.s. Sometimes the battery drain issue after firmware update might cause by some disturbance from the 3rd party apps, so that one of your phone performs well yet the other does not. And the Factory Reset is a good way to save the issue.
