Higher Battery consumption after upadte from .82 to .84
AsusYouzr
Rising Star II
Model Name: Max pro m1 4/64 gb
Firmware Version: .84
Rooted or not: not rooted
Frequency of Occurrence: since last update
APP Name & APP Version (If your issue relates to the app): battery draining quickly.
High consumption of battery noted ..after my last update from .82 to .84...... 82 version is the best optimization for battery.. after normal chrome web browsing ( only browsing..not playing video like YouTube etc) .. Battery reduces 10 percent on this new 84 version...but when i was on 82 version....the consumption was only 6 percent to maximum 7 percent. But headfone Sound quality is improved ...just fix battery consumption on next update... I am not a heavy user nor i use unnecessary apps on my phone.
9 REPLIES 9
AsusYouzr
Rising Star II
Anyone who wants good battery backup...plz stay on .82 version firmware.
pvkrishnanunni
AsusYouzr
082 also had battery drain
qromodynmc
Rising Star II
Yeah, since last 2 or 3 update, my screen on time has been reduced to 8 to 10 hour, it used to be around 12 hour back then. So, it's not really about 084 or 082, it been like this for a while.
victor010
Zen Master III
Hi, when you say that your SOT (Screen on Time) has gone down, can you share the SOT after trying the below:
1. Charge the battery to 100% & use as per your normal usage pattern
3. settings => Battery => Check the screen & share the same.
Please follow below steps may improve battery backup:
1. Close apps that are not used (Bluetooth, WiFi, GPS, etc.)
2. Adjust sleep time and brightness (Settings > Display)
3. Boost memory when you see memory consumption is high with no app running,
4. check for background running applications, stop/disable unwanted apps, you can manage apps from auto-start manager.
