GPS fix
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
07-24-2019
02:25 PM
- last edited on
01-15-2024
11:59 PM
by
ZenBot
ZF Model: ZB631KL
RAM: 6G
Firmware/APP Version: 16.2017.1905.065-20190507
Frequency of Occurrence: Not always
Rooted: No
APP Name: GMaps, Waze
When I start using GMaps or Waze, GPS is not fixed for several minutes. I also switched off the phone, 2 or 3 times, but with no results. I use the navigator but the point is out from the itinery. I never rooted the phone. It seems that the GPS sensor is not working correctly. After several minutes, finally the phone start to work. Updated to Android Pie recently. Could be a software problem? I need to be solved. Regards
RAM: 6G
Rooted: No
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-25-2019 11:00 PM
Hi hrtracci
Can you help me confirm that phone is up to date? The latest version for ZB631KL is WW_16.2017.1906.067.
What's your location settings? For best performance, please set the mode to "High accuracy"
If the problem exist, please help testing your phone GPS functionality under safe mode.
In safe mode, only the factory pre-installed applications will be loaded.
For instructions, please refer to the link below:
https://www.asus.com/support/faq/1005163
Thank you:)
