Features that can be added in Zenfone Max Pro M2 (Version WW-17.2018.2007.428)
Some features that can be added and that can be removed:
1) "Close all applications" button in recent screen also can be added.
2) Even after replacing files with files go, certain settings is asking whether to open it in files or files go. (Unnecessary wasting space with two apps of same kind).
3) Remove some of the apps like Facebook, Instagram and Messenger.
4) Bubble notification is enabled but no bubbled notifications till now. Please work on this.
5) Nearby Share doesn't turn on the wifi when "turn on wifi" button is clicked.
These features are just addons (to the existing android 10 beta build Version WW-17.2018.2007.428) to improve the experience.
Suggest any addons in comments if you find any.
5 REPLIES 5
vamsi
https://zentalk.asus.com/en/discussion/36614/features-that-can-be-added-in-zenfone-max-pro-m2-versio...
  1. Worth having it.
  2. I only have files app in my mobile, i thing files go can be uninstalled.
  3. Use the below link to uninstall all your unwanted apps. Asus is not going to remove them.
  4. I think that's not available in A10, i haven't used any other A10 devices to check bubbles specifically. Its widely available in A11.
  5. I dont know about that yet.
https://forum.xda-developers.com/max-pro-m2/how-to/guide-remove-stock-apps-root-t3882356
If you follow that method the app is hidden for that particular User and not uninstalled.
Yes, the signal strength came up after switching off and on Airplane mode. Thank you
Let Asus(@Victor01_ASUS ) also fix the bug, which is making it disappear.
Chat bubbles are introduced in A10 (developer options) so can be made available in A10.
I dont think Asus will provide A11 for Zenfone Max Pro M2.
