09-03-2020 07:28 AM
09-03-2020 10:09 AM
fkemil123456When connected via USB, click on File Transfer option, & then you can directly copy all files from mobile to your computerWhere I connect USB to Zenfone max pro m1 to transfer the movie through inbuilt files app , it never transfers 100% ,even if I remove through safely eject, then also movie stuck in middle of the movie. So any suggestions
Data is not transferring
09-04-2020 02:44 AM
09-04-2020 05:56 AM
09-04-2020 06:29 AM
fkemil123456This happen's when you are transferring any files bigger than 1gb. I have been experiencing this bug since android Oreo but recently it seems to be fixed(atleast in my device).
I have the latest firmware update on my device.It some software problem with files app,while using mi file manager it was able to do the job,but taking lot of time
