07-13-2020 12:23 PM
07-16-2020 06:14 AM
veeharish2005If the device is switched off & charged, approx it should take how much time?, as I have another brands phone 1 is of 5000mah & another one of 3500 mah approx, both it takes almost 2 hours 15 min approx to full charge, whether it is ON or OFF. I'm using max pro 1st time it charge in less than 2 Hours when phone is switched off, after that it takes almost 3 Hrs to full charge in OFF Condition. Also, Asus had provided fast charging, for that what does it mean should gt full charge in less than 2 Hour?https://zentalk.asus.com/en/discussion/comment/97093#Comment_97093
No, they advertised this phone to charge in 2 hours and 45 minutes at launch. But every company test's their devices in the best case scenario.
Charging speed will be affected by the temperature of the device , charging speed will change at various percentage of the battery. It will also be affected by the background processes (antivirus scanning in the background etc) so taking all of this into account your device will be charged in 3 hours to 3:15 hours.
07-16-2020 06:18 AM
Sardar JiReply is provided, but when I saw on their site, it is mentioned as approx 2 hrs 40 min to full charge.https://zentalk.asus.com/en/discussion/comment/97091#Comment_97091
This is 5000 mah battery should it still take less than 2 hours with the stock charger?
07-16-2020 06:56 AM
AJ1Source link?https://zentalk.asus.com/en/discussion/comment/97093#Comment_97093
07-16-2020 11:12 AM
07-16-2020 12:03 PM
AJ1Asus zenfone max pro m1/M2 does not have fast charging it only charges at 10w or below (this was like the standard charge speed for most of the device released in 2018) every company advertised their 10w charging solution as fast charging. If you are talking about oppo or realme devices, they charge at 30w or 60w that is why most recent devices with 4000 to 5000mah battery will charge faster than Asus zenfone max pro m1/M2.https://zentalk.asus.com/en/discussion/comment/97098#Comment_97098
