ZF Model: ZB602KL
RAM: 6G
Firmware/APP Version: OPM.WW_Phone-15-2016.1902.340-20190216
Frequency of Occurrence: Almost all the time
Rooted: No
APP Name:
Since I purchase the phone I have been experimenting lot of networks issue (bad Wlan and 3G signal), I was specting for some resolution in some system upgrade, but it did not happen. I can deal with the Wlan bad signal, but the 3g reception problem is annoying.
I saw that there a ton of posts about the 3g networking issue, and there are no formal resolution for it...
Please, could you try to do something from software perspective, I do not care if there are some advanced option to use more battery to the radio, but I have a phone that have battery for 3 days, but im not able to be sure if im receiving the calls, or IM....
Thanks
AC.
