03-24-2021 10:08 AM
03-24-2021 07:27 PM
03-25-2021 02:24 AM
Christine_ASUSmeans we can not use CA feature on my Asus Max Pro M1 device I'm a right...?Hi Singh
Thank you for your asking. Please note that CA requires multifaceted supports not only from hardware/software but also from the carriers, involved the compatibility between these two conditions.
Kindly check "Tech Specs page - Network Standard" of your model on your country's ASUS official website (each region may have slightly different spec), and check "Network Standard" of your sim card with local carriers.
03-25-2021 07:55 PM
03-25-2021 08:57 PM
Christine_ASUSI'm purchased this device in India...Which means you can use CA feature if the support channel of your sim carrier are compatible with the support channel of your country SKU.
Which country did you purchased the device?
