first you download this version..
Version MaxProM2_downgrade_to_9
2020/04/291.54 GBytes
ASUS ZenFone Max Pro M2 Software downgrade to target Image Version: WW-16.2017.1912.072 (Android 9 Pie) by using MicroSD card for WW SKU only* Please follow step 6 . System downgrade will wipe all the personal data, please backup your important data before system downgrade.
Steps of Update:
1. Prepare a MicroSD card.
2. Check software version of your device**
3. Only apply to same SKU update, Example: WW->WW, CN->CN, TW->TW, ID->ID.
4. Software update cannot transfer the software SKU.
5. Wrong SKU may cause update failure, please update the same SKU version only.
and follow these instruction...
www.asus.com/support/FAQ/1042349Note -take ....backup frist of all data
remove fingerprint password
before do this
after this check ota update for WW-16.2017.2009.097 or mannualy try
