Bugs In Asus ZM Pro M1 Android 10 Beta 3
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
07-03-2020 02:53 AM
Build Number-
(QKQ1.WW_Phone-17.2017.2006.429-20200614)
Bugs Which was also present in Beta 1 & beta 2.and still not fixed in this new beta 3.
1) Sound quality through earphones is still weird. (No bass effect)
2) Setting suggestion is not removable. {E.g-Customize your ZB601KL suggestion in setting} (screenshot attached)
3) Huge gap in navigation button while using android 10 special gesture navigation. (Screenshot attached)
4) Google search widget is not removable.
5) Charging vibration is too loud.
6) no option to desable vibration when unlock with fingerprint.(when fingerprint rejected its vibration is GOOD and Natural but when fingerprint accepts its vibrate like android 9 charge connect vibration and no option to desable it)
7) discharge in idle mode.
😎 something app menu blank.(screenshot attached)
9)in dark mode ,white background in Setting search .(screenshot attached)
10)when i call myself from another phone, its showing call notification after 4 seconds,and then asus rings for only 2 second.(during total 6 second of ringing)
*battery*
When Charging
15%-40% =200mA-400mA
40%-50% =1600mA
50%-70% =1400mA
70%-90% =1000mA
90%-95% =400mA(showing Rapidly charging )(screenshot attached)
95%-100% =300mA-400mA (Not rapidly, Normal charging)
Battery backup is good.
How to Fix sound problem temporary:
for sound problem though earphone - use poweramp app-set output Hi-Res Outout-select Sample rate 384kHz then restart your phone and quick play any song from poweramp through earphones.and turn the bass knob to full in Poweramp app equilizer. (Now you will have good sound quality only in poweramp app )
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-03-2020 10:55 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-03-2020 11:31 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-04-2020 12:54 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-04-2020 02:31 AM
ankitsh0707Not like original but its near to original..Does poweramp high res. give original like experience?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-04-2020 04:13 AM
sujanjsr0Bug 3 is not a bug. After 75% battery voltage will decrease to make sure battery life is good. For devices with Qualcomm processor with Quick Charge 4 (except OnePlus, Oppo, Realme chargers), devices after 75% will decrease battery voltage for better battery health.Bugs in Asus Zenfone Max Pro M1 Android 10 Beta 3
Build Number-
*battery*
When Charging
40%-50% =1600mA
50%-70% =1400mA
70%-90% =1000mA
Battery backup is good.How to Fix sound problem temporary:
for sound problem though earphone - use poweramp app-set output Hi-Res Outout-select Sample rate 384kHz then restart your phone and quick play any song from poweramp through earphones. (Now you will have good sound quality only in poweramp app )
