Battery
Jun
ZF Model: ZE554KL
RAM: 1G
Firmware/APP Version: Android 9
Frequency of Occurrence: Always
Rooted: No
APP Name:
Please fix the battery optimization ... This gigantic 5000mah battery has been outlasted by others 3000 mah battery.... This is frustrating...
7 REPLIES 7
Jun
Before the pie update... My 100% fully charged battery max pro m1 would last me a whole day of use. This include ocaasional gaming, heavy internet use and music, now after pie update the battery would only last half day, same routine, but the biggest drop is while on game.
Y_ASUS
Zen Master I
ftabuac posted on 2019/6/14 13:08 Before the pie update... My 100% fully charged battery max pro m1 would last me a whole day of use. ...
Hi ftabuac, If you feel like the battery drains during using specific apps, we would suggest you test how much the app drains after using it for a certain time. We would suggest you clear the background apps, and check how much battery is consumed from 100% after using the app for a certain time (e.g. 30 mins or 1 hour.) Please show me a screenshot of the battery usage after testing. Settings > Battery > Three dots on top right > Battery usage. Thanks for your help 🙂
@Jei_ASUS, would like to inform you that since pie upgrade, the mobile phone battery is getting drain out even without usage. I have stopped all apps, background data usage and notifications. Despite no background services mobile is using more battery in standby. I visited the service centre to format mobile but they downgraded it to android 8 . Later mobile was having automtic update enabled which cause it to upgrade pie. I request you to kindly escalate this issue and create a patch.
