battery draining
athenswift
ZF Model: ZB601KL
RAM: 6G
Firmware/APP Version: 0.59
Frequency of Occurrence: Always
Rooted: No
APP Name:
my battery is draining very fast please pry update for this
burgman
Hi, can you share the SOT after trying the below steps: 1. Charge the battery to 100% & use as per your normal usage pattern 2. When the battery strength reaches 10%, go to settings = Battery => Tap on the battery icon & share the graph 3. Settings => Battery => Check the screen & share the same
