Battery draining problem after latest update
Model Name:
Firmware Version:
Rooted or not:
Frequency of Occurrence:
Asus max pro m1
.087
Not rooted
Constant
After updating to latest version 087 I am getting about 2-3 hrs less battery backup
And also about 20-30% overnight battery drain
I tried calibrating battery but it didn't work
AJ1
Rising Star II
jatinrockstar69
  1. Model Name:
  2. Firmware Version:
  3. Rooted or not:
  4. Frequency of Occurrence:
Asus max pro m1
.087
Not rooted
Constant
Go to service center for this, the y will check & resolve this
victor010
Zen Master III
Hi, we'd request you follow the below steps:
1. Clear system cache.
2. Try the same under safe mode:
Hold the power button for 5 seconds => When the screen flashes with option => Press & hold power option => You will get an option to restart in safe mode
3. If still you face the issue
factory reset your phone after taking a full backup : https://www.asus.com/support/FAQ/1006346/
4. Last option would be to visit the service center to have
a check. Locate here: https://www.asus.com/in/support/Service-Center/India
