Battery drainage is too fast
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
02-04-2021
10:03 PM
- last edited on
01-16-2024
02:05 AM
by
ZenBot
Model Name: Zenfone max pro (m2) or Asus_X01BDA
Firmware Version: PKQ1.WW_Phone-16.2017.2011.105-20210108
Rooted or not: Not rooted
Frequency of Occurrence: every time
APP Name & APP Version (If your issue relates to the app)
My Asus phone's battery used to last 2 days easily, but from the past 6 months or so the phone drains very quickly. The phone barelt gives a one day battery with around only 2 hours of screen time. Asus please help me rectify this issue. I am hopeless now, I think even iPhone see with half the battery size of this phone gives more sot than asus zf max pro m2.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-05-2021 01:20 AM
Hi, when you say that your SOT (Screen on Time) has gone down, can you share the SOT after trying the below:
1. Charge the battery to 100% & use as per your normal usage pattern
3. settings => Battery => Check the screen & share the same
Also, please follow below steps may improve battery backup:
1. Close apps that are not used (Bluetooth, WiFi, GPS, etc.)
2. Adjust sleep time and brightness (Settings > Display)
3. Boost memory when you see memory consumption is high with no app running,
4. check for background running applications, stop/disable unwanted apps, you can manage apps from auto-start manager.
5. Check the following article for more information: https://www.asus.com/in/support/article/604/
