Battery drain in Zenfone max pro m1
Model Name: ASUS_X00TD
Firmware Version: PKQ1.WW_Phone-16.2017.2002.061-20200219
Rooted or not: No
Frequency of Occurrence: Daily
Battery gets drained from 99% to 75% within few hours (5hours) even when airplane mode is on and kept idle. Battery is getting drained even when I'm not using my phone.
73 REPLIES 73
dayabudh
I am also facing same issue but they are not replying anything i will never buy such waste product of Asus
yasyas786
even i am having the same problem after the update. Asus team plz assist
achuth24j00
jothi
Battery drain issue seen in my Maxpro M1 device also past one week.
Reset done to factory settings, overnight changed to airplane mode and tested, nearly 40% battery draining.
Build PKQ1.WW_Phone-16.2017.2005.82-20200506
Phone not rooted.
Same to me could you check if it is happening even in switched off condition?
Because same problem is on me.
manojreddy_buda
Rising Star I
jothi
Cache partition cleared, Factory reset done, battery saver on, all background access restricted, WiFi, bluetooth, location off. Verified 3rd party usage, no surprise on 3rd party app battery usage. Digital wellbeing option off. Really frustrated past few days on battery drain issue.
Why are you showing your IMEI numbers to all??
Remove the image.
jothi
Not able to delete pic uploaded with IMEI. Moderator help to remove the image with IMEI number
