BATTERY DRAIN IN IDEAL TIME IN MAX PRO M1
bhaveshsuthar23
In max pro m1 after update of .084 . The battery consumption increase in ideal mode when phone not in use . I try all methods for reduce this issue
1. Clean all apps in background
2. Data turn off
3. Turn on airplane mode
4. Recalibrate Battery
Ibam tried all methods for this issue even my issue not resolved . Plz ask ur developers to fix it i think 063 firmware is a best for battery and performance . In 084 the battery drain in ideal mode is 30 to 40 % drain are there . My phone was charged at 60 % and i woke up on morning and i saw in phone the charge is 20 % .
victor010
Zen Master III
Hi, when you say that your SOT (Screen on Time) has gone down, can you share the SOT after trying the below:
1. Charge the battery to 100% & use as per your normal usage pattern
3. settings => Battery => Check the screen & share the same
You may also follow the below steps:
1 . Factory reset your phone after taking a full backup : https://www.asus.com/support/FAQ/1006346/
2 . Last option would be to visit the service center to have
a check. Locate here: https://www.asus.com/in/support/Service-Center/India
