ZF Model: ZB631KL
RAM: 6G
Firmware/APP Version: 16.2017.1908.070
Frequency of Occurrence: when charging the battery
Rooted: No
APP Name: Zenfone max pro M2
why is the battery charging stopped at 68%,
even though the LED indicator still shows the charging process .
charging often stops when the battery reaches 68%.
and as if it looks like a broken connection,
When I charge the battery and the battery is charged 68% it always stops, the led indicator is still red but the charging stops .
I decided to disconnect the charger, and when the battery 67% I recharged the battery ,as a result the refill runs normally up to 100%.
such events often occur when charging batteries.
Is this a bug or a system error?
please investigate and fix this problem, because this is very annoying.
