Audio output Feedback for max pro m2-(434)
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
12-23-2020
06:30 AM
- last edited on
01-16-2024
04:18 PM
by
ZenBot
Dear Asus, (please fix it down... in next update)
1- Max pro m2 audio output is very worst in 434 beta version..There is no base in it both speaker and earphone.
While the both frimware (97/101 pie) is many times better.... Not as good/loud as oreo But the best to hear.
Other than that everything is fine so far..
10 REPLIES 10
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-26-2020 12:27 AM
kingpubg4477Sound improvement on Android 10, WW-17.2018.2012.434 firmwareInaccessible or not found
Option for Windows 10:
1. Install Minimal ADB and Fastboot. (I installed adb-setup-v1.5.2).
2. Go to: Settings - About phone - Find the build number and tap on it several times until you see: "now you are a developer."
3. We go: System -For developers - USB debugging - Turn on.
4. We connect the phone to the computer (without turning off the phone), a message will appear like: enable USB debugging - allow. Android Composite ADB Interface will appear in Device Manager.
5. Run PowerShell as administrator and enter the commands:
adb devices
adb shell pm list packages
adb shell pm disable-user --user 0 dk.icepower.icesound or, if you want to completely remove: adb shell pm uninstall -k --user 0 dk.icepower.icesound
6. After restarting the device and check the sound.
I managed to fix the sound.
- « Previous
- Next »
