Audio output Feedback for max pro m2-(434)
pankajfhz
Dear Asus, (please fix it down... in next update)
1- Max pro m2 audio output is very worst in 434 beta version..There is no base in it both speaker and earphone.
While the both frimware (97/101 pie) is many times better.... Not as good/loud as oreo But the best to hear.
Other than that everything is fine so far..
10 REPLIES 10
kingpubg4477
Inaccessible or not found
kingpubg4477
Abhirup
https://zentalk.asus.com/en/discussion/comment/142284#Comment_142284
I have tried this and the sound is clear and loud with base. Try it.
It show inaccessible or not found
pankajfhz
I have already done But not as good as it was in 97/101
only little effect use on earphone.
but guy this process is not authentic go own risk.Similarly, Asus phones have fewer problems
Abhirup
First install adb drivers for max pro m2 from this link
https://www.xda- developers.com/quickly-install-adb
And follow the procedure.
Then copy and paste this command
adb shell pm uninstall -k --user 0 dk.icepower.icesound
victor010
Zen Master III
 Hi there, thank you for highlighting the issue. We have made a note of the feedback and will share it with the relevant team.
