04-15-2020 11:05 AM
04-15-2020 12:53 PM
rrajput.rohit11Try "Network Reset" from Settingns -> System -> Advanced -> Reset -> tap on "Reset Wifi, mobile & bluetooth" option.Hi!!
Asus Zenfone Max Pro M2 wifi is disconnecting automatically several times in just 10 seconds.. However, My brother using Apple phone, samsung but there wifi is not disconnecting. There is no internet issue in my home but still its is disconnecting. I have switched off my phone and on it several times but still it is not working.
Please give me solution for it.
Thank You
05-12-2020 03:15 AM
07-26-2020 06:27 AM
07-26-2020 06:28 AM
victor2020Hi Victor, I'd try all of ur request and suggestions. but it didn't work. please help me.Hi, we'd request you follow the below steps:
1. Clear system cache.
2. Try the same under safe mode:
Hold the power button for 5 seconds => When the screen flashes with option => Press & hold power option => You will get an option to restart in safe mode
3. If still you face the issue factory reset your phone after taking a full backup.
