Asus Zenfone Max Pro M2 wifi is disconnecting
Hi!!
Asus Zenfone Max Pro M2 wifi is disconnecting automatically several times in just 10 seconds.. However, My brother using Apple phone, samsung but there wifi is not disconnecting. There is no internet issue in my home but still its is disconnecting. I have switched off my phone and on it several times but still it is not working.
Please give me solution for it.
Thank You
Comments
Try "Network Reset" from Settingns -> System -> Advanced -> Reset -> tap on "Reset Wifi, mobile & bluetooth" option.
Then turn off your phone and get into the Recovery Menu and perform "wipe partition cache" and then "Reboot".
After rebooting, go to settings and connect to your home Wifi by entering the Wifi password. Try static IP details for more stable wifi connectivity.
Hi, we'd request you follow the below steps:
1. Clear system cache.
2. Try the same under safe mode:
Hold the power button for 5 seconds => When the screen flashes with option => Press & hold power option => You will get an option to restart in safe mode
3. If still you face the issue factory reset your phone after taking a full backup.
Hi, i have the same issue on my Max Pro M2. I also try Factory Reset. But its useless. Can someone help me? my realme phone and other phones are connected to the router is not disconnecting. While mine is disconnecting every 5 seconds. Kindly help me with this please? Thank you
Hi Victor, I'd try all of ur request and suggestions. but it didn't work. please help me.
