04-18-2025 11:42 PM
I have just installed the stock firmware on my phone. I turned on the developer option but it is not showing the oem unlock option. Why?
I want to unlock the bootloader of my phone. How do I unlock the bootloader of #X00TD?
04-21-2025 05:42 PM
@Prince6012
For ZB601KL/ZB602KL, there will no longer be any system updates and maintenance (including ZenUI Launcher , server & unlock tool).
Thank you for your understanding and support.
04-22-2025 12:44 AM
Please provide some solution. I want to install latest security updates via custom roms.
05-05-2025 07:50 AM
I have the same problem.
Did you try to tape *#*#checkin#*#* in the phone app ? Normally it permit the oem unlock, but it doesn't work for me.
I'm searching a solution too...
05-05-2025 10:38 AM
I'm serching a answer here : https://forums.ubports.com/topic/10965/unlock-bootload-asus-zenfone-max-pro-m1/4?_=1746464532605
but it doesn't work for the moment....
