ASUS ZENFONE MAX PRO M1 ANDROID 10 LATEST UPDATE STARTED ROLLING OUT
Asus_mod67
Model Name:ZB601KL/ZB602KL
Firmware Version:17.2018.2012.438
Rooted or not: NOT
Frequency of Occurrence:
APP Name & APP Version (If your issue relates to the app):NEW
ASUS ZENFONE MAX PRO M1 ANDROID 10 LATEST BUILD UPDATE IS ROLLING OUT
Zentalk release notes :-
https://zentalk.asus.com/it/discussion/42096/201222-zenfone-max-pro-m1-zb602kl-ww-17-2018-2012-438#l...
PROOF:-
66 REPLIES 66
Yachendra
Rising Star II
zaidnabi123
https://zentalk.asus.com/en/discussion/comment/141887#Comment_141887
Tell me the steps to uninstall icepower haven't done it before. I can't play pubg with this earphone sound. I was happy with pie 😑😑
1) You should have Laptop/PC & ADB drivers should be installed in system.
2) Activate developer options & Enable USB debugging in your mobile.
3) Now connect your mobile to Laptop/PC and open the command prompt.
4) Type "adb devices" in command prompt and enter. Your device Serial number will be displayed. That mean you can use adb commands now.
5) Now type "adb shell pm uninstall -k --user 0 dk.icepower.icesound" in command prompt and enter.
After above steps restart your device and check the sound.
sujanjsr0
Rising Star II
No dsta loss, updated from letest pie.
Earphone sound quality is excellent 😍🤤
Better than pie
rana_vishal73
Rising Star I
Yachendra
https://zentalk.asus.com/en/discussion/comment/141656#Comment_141656
I tried download the firmware, where WW version has only 11.99 MB file(Might be broken one uploaded in server which we faced previously for one beta file).
And, JP version has 1.23 GB. Not downloaded since it's different SKU for Indian device.
Server Link for JAPANESE version:
https://dlcdnets.asus.com/pub/ASUS/ZenFone/ZB601KL/UL-ASUS_X00T-JP-17.2017.2012.438-user.zip
Server Link for WORLDWIDE version:
https://dlcdnets.asus.com/pub/ASUS/ZenFone/ZB601KL/UL-ASUS_X00T-WW-17.2017.2012.438-user.zip
"https://dlcdnets.asus.com/pub/ASUS/ZenFone/ZB601KL/UL-ASUS_X00T-WW-17.2017.2012.438-user.zip"
The link has started working the file size is of 1.7gb
Not applicable
kumardaksh314
OMFG! This build 438 is smooth as hell without any bugs!!! Sound is better than Pie. No low minimum brightness.
Bugs NONE!
I upgraded from Pie without factory reset. I'll write detailed review though i believe this build should be pushed as OTA to Pie.
Thank you to the developer team @Christine_ASUS 😍
What about battery backup or charging speed??
aparajitlal_kum
kumardaksh314
Bugs NONE!
You don't get any suggestions in settings, how to disable it ?
