ASUS ZENFONE MAX PRO M1 ANDROID 10 LATEST UPDATE STARTED ROLLING OUT
Asus_mod67
Model Name:ZB601KL/ZB602KL
Firmware Version:17.2018.2012.438
Rooted or not: NOT
Frequency of Occurrence:
APP Name & APP Version (If your issue relates to the app):NEW
ASUS ZENFONE MAX PRO M1 ANDROID 10 LATEST BUILD UPDATE IS ROLLING OUT
Zentalk release notes :-
https://zentalk.asus.com/it/discussion/42096/201222-zenfone-max-pro-m1-zb602kl-ww-17-2018-2012-438#l...
PROOF:-
66 REPLIES 66
zaidnabi123
kumardaksh314
https://zentalk.asus.com/en/discussion/comment/142158#Comment_142158
clear the the app data. it never bothers me anymore.
Edit: see yourself even till no more suggestions
I did clear the data but it's still the same
Krunal
Yachendra
https://zentalk.asus.com/en/discussion/comment/141888#Comment_141888
1) You should have Laptop/PC & ADB drivers should be installed in system.
2) Activate developer options & Enable USB debugging in your mobile.
3) Now connect your mobile to Laptop/PC and open the command prompt.
4) Type "adb devices" in command prompt and enter. Your device Serial number will be displayed. That mean you can use adb commands now.
5) Now type "adb shell pm uninstall -k --user 0 dk.icepower.icesound" in command prompt and enter.
After above steps restart your device and check the sound.
Does it also increases in ear call sound through earpiece?
aparajitlal_kum
kumardaksh314
Not working
Any one who has fixed this?
aparajitlal_kum
kumardaksh314
https://zentalk.asus.com/en/discussion/comment/142165#Comment_142165
Can't tell about that. Add a temporary email & later remove it see if this do the trick.
Does your Google Play store is certified or not? Check in Store settings.
My CTS failed. Maybe its beta that's why.
Playstore says certificated for me .
zaidnabi123
kumardaksh314
My device is certified and safety net is also true
