Asus zenfone max Pro m1 .063 update Extreme battery draining problem.
rohitashva_dong
Hello Asus,
I have been facing extreme battery draining problem since I updated to the latest version .063. This update has ruined my mobile experience. I m getting 1 hour of screen on time and that is perhatic. Mobile is also heating a lot. Average temperature of my mobile remains around 43°C. It feels apps are battling to each other inside the mobile all the time. Even if I don't use my fully charged mobile for 7hours (during sleep), my battery goes to zero.
Charging time has also pethatically increased. It takes forever to charge if I keep my internet on during charging. Buttttt when I turn off the internet connection, mobile gets fully charged in approx 90 minutes only. And if I use my mobile during charging (while keeping data on) , charging percentage decreases instead of increasing.
Everything is fine except this issue. I love this phone, it used to be really great in terms of battery performance. Please fix this problem in next update or I'll have to sell my mobile.
Note: last 2 updates (.061 and .063) ruined the experience. And battery was working superfine in previous versions prior to .061.
67 REPLIES 67
Dheena
And heating issues too, 0.61 update is awesome after updates heating issues came and i never experienced before, during charging also its heating
subhaschatterje
I am also facing the same problem I have Asus Max pro m1 model. It's been a month fast discharging battery .in night battery is discharging 20 to 30% even in flight mode. Full charging is lasting only for half day. Fix this issue as fast as possible .how can we use the phone if discharging happens at this high rate. If this issue continues we have to change the handset. Some of my known people having the same handset are also facing the same problem.
prithvi_2255
i talked with the asus people, they are saying that i have water log issues that is why my battery is draining ... ?
did anyone of you had any water damage earlier to the phone ?
rohitashva_dong
prithvi 2255
Nope I didn't have such issue ever. All I know is that after the last update, phone started to heat a lot and battery drain was at extreme. That heating problem consumed my battery earlier than expected. I even changed the battery (not original because of Covid 19 lock down) but heating issue was still there and battery was draining at equally same rate. And finally I set my mind to change the handset. Nd now m pretty happy with my new phone.
mailtompmani
subhaschatterjee06
Same here. 😭😭😭
