(ASUS_X00TD) MAX PRO M1 TOLONG UPGRADE WIFI 2.4GHZ KE 5GHZ
Max pro m1 fon dah bagus tp masih 2.4ghz ..baik pakai Sony je z3 walaupon dah lame tp 5ghz .. kenapa masih 2.4 GHz ? Adakah akan di upgrade ke 5 GHz ??
4 REPLIES 4
Max_Pro1
untuk itu diperlukan peningkatan perangkat keras. jadi tidak mungkin
Haha seriously ,wifi selalu disconnect ? Why ?
Y_ASUS
Zen Master I
Hi khairulasraf0000, To avoid any possible misunderstanding, we would suggest you describe your situation in English. Thank you for your help 🙂
If i understood you right, your question is: Why ZenFone Max Pro M1 doesn't support 5 GHz Wi-Fi and could it be fixed? Answer is simple as question: Wi-Fi module of M1 don't support 5 GHz range, it means that phone can't "see" networks in this frequency range. Therefore, there is no way to implement 5 GHz Wi-Fi support through software update. Hope my answer helped you 😃
