Asus Max Pro M1
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
05-11-2020 11:25 PM
Model Name:ASUS_X00TD
Firmware Version:424
Rooted or not:No
Frequency of Occurrence:
APP Name & APP Version (If your issue relates to the app):Google Playstore shows updates which is already updated before.I have to update each app 2 to 3 times in a week after update release for an app.
I have updated android 10 version 424 via manual update which is provided on asus max pro m1 firmware page.
1.Unable to remove suggestions on settings
2.Charging time is same and it took 2 hr 50 min to charge my device
3.The speaker and earphones output is low.
4..Finger-print recognisation time is very bad
The time taken to unlock the device after recognisation finger is bad compared to time taken in pie
5.Sometimes Wifi toggle shows connected on notification panel but when i drag notification panel it shows as not connected
6.Unable to move Google widget on home screen
7.Picture in Picture mode doesn't work properly
8.Call recording is not working
There are some bug fixes too in version 424
1.I can turn on/off mobile data while device is locked
2.There is no menu bugs in android 10 compared to pie
3.Wifi calling is enabled for jio
4.Camera2api is enabled
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-13-2020 09:58 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-13-2020 10:22 PM
doradla.rohithone more issue bro... when u connect your Bluetooth earphones.. the output quality is verrry poor .. it like you are listening a recorded audioPlease tell us some basic information before asking for help:
- Model Name:ASUS_X00TD
- Firmware Version:424
- Rooted or not:No
- Frequency of Occurrence:
- APP Name & APP Version (If your issue relates to the app):Google Playstore shows updates which is already updated before.I have to update each app 2 to 3 times in a week after update release for an app.
Asus Max Pro M1
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-15-2020 11:25 PM
doradla.rohithhttps://zentalk.asus.com/en/discussion/comment/79751#Comment_79751
I am facing a wifi bug where it shows connected and when i drag notification bar it shows as not connected
Sometimes it shows like this while it is connected to wifi network
Wifi shows connected and when i drag notification bar it shows as not connected
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-20-2020 11:39 PM
- « Previous
- Next »
