Asus Max Pro M1
doradla_rohith
Model Name:ASUS_X00TD
Firmware Version:424
Rooted or not:No
Frequency of Occurrence:
APP Name & APP Version (If your issue relates to the app):Google Playstore shows updates which is already updated before.I have to update each app 2 to 3 times in a week after update release for an app.
I have updated android 10 version 424 via manual update which is provided on asus max pro m1 firmware page.
1.Unable to remove suggestions on settings
2.Charging time is same and it took 2 hr 50 min to charge my device
3.The speaker and earphones output is low.
4..Finger-print recognisation time is very bad
The time taken to unlock the device after recognisation finger is bad compared to time taken in pie
5.Sometimes Wifi toggle shows connected on notification panel but when i drag notification panel it shows as not connected
6.Unable to move Google widget on home screen
7.Picture in Picture mode doesn't work properly
8.Call recording is not working
There are some bug fixes too in version 424
1.I can turn on/off mobile data while device is locked
2.There is no menu bugs in android 10 compared to pie
3.Wifi calling is enabled for jio
4.Camera2api is enabled
18 REPLIES 18
Tanu
Exactly the same issues I'm also facing. Asus, please tell us the timeline of the final stable update.
1234prabhat
doradla.rohith
  1. Model Name:ASUS_X00TD
  2. Firmware Version:424
  3. Rooted or not:No
  4. Frequency of Occurrence:
  5. APP Name & APP Version (If your issue relates to the app):Google Playstore shows updates which is already updated before.I have to update each app 2 to 3 times in a week after update release for an app.
Asus Max Pro M1
Did cam2api previously enabled on your device.
After update did you reset ..
doradla_rohith
1234prabhat
https://zentalk.asus.com/en/discussion/28136/asus-max-pro-m1
1.Camera2api enabled after updating to android 10 in manual update from asus max pro m1 firmware page as I mentioned on zentalk
2.I have not reset my device
I just removed all pattern /pin /fingerprint security before updating to android 10 via manual update
ZT-6dd371a6
The audio in earphones with asus Dolby apk had a lot of disturbances post upgrading to andeoid 10 2nd update. the low and high frequency notes are not that effective than that of with 9 stable version.
