Hi
dr87dodiaThank you for your asking. If it is impossible to access the service center during Covid-19 period, please try
# Call us:
https://www.asus.com/support/CallUs# ASUS repair center in the country of your residence:
https://www.asus.com/support/Service-Center-All-Countries/Furthermore, what kind of battery issue are you facing? Is there any zone heating up while using/idling? How long does the battery be used?
Before sending your units to repair center, I came up some stay-at-home troubleshooting tips for you to try on
1. Enter "Safe Mode" and leave a 80%-100% phone in sleep(idle) mode in a night.
https://www.asus.com/support/FAQ/1005163/If the battery works well in "Safe Mode", please check on any disturbance from the installed 3rd party Apps.
2. If the issue remain the same in "Safe Mode", please try "the Factory Reset"
Settings>System>Reset options>Factory data reset
Please note that once the Factory Reset is completed, all data, apps, settings and personal information will be deleted.
