Asus max pro m1 android 10
milantailor254
Model Name:ZB601KL
Firmware Version:424
Rooted or not:no
Frequency of Occurrence:
I've updated to Android 10 yesterday and it's a very good update.
The battery life is great and good backup
Wifi calling is active as you can see in screen short
The gesture is working perfectly and there are no lags since update.
No heating issue and charging time is same and lil bit improve I would say.
Force dark mode is perfect in work.
Sound is too good but it does cracks if the volume is full, full volume isn't even necessary in medium level sound is great trust me.
For basic and daily use it's the best update.
Don't listen any rubbish about it trust me it's good!!🙇🏻
36 REPLIES 36
dassumit391
PUBG PERFORMANCE too low FPS Drop after this update..😡
Chirag_1910
milantailor254
  1. Model Name:ZB601KL
  2. Firmware Version:424
  3. Rooted or not:no
  4. Frequency of Occurrence:
Try changing your display size to small, then you will notice the problems in gesture.
And most of the bugs reported are not regarding gesture or heating issue but other problems.
However audio problen is there compared to previous versions, maybe you are not facing but it is there.
abhir7861
vaibhavgupta2512000
When we get the updates through OTA... In max pro M1...
Mid May as confirmed by Asus
Dev_Kumar
Please add screen colour options in display section in Android 10 stable update
ganjack_333
milantailor254
  3. Rooted or not:no
Frnd we also flash this update. But I am not agree with you. Coz I facing many issues .. also I don't know you are a power user or just casual but disappearing if notification bar and mostly sound quality which you talking about is a serious crap . So my friend I insist you please push your phone to a limit where you know the power of your device .. max pro m1 it's a great device ...
