04-30-2020 07:58 AM
05-04-2020 08:59 PM
AKPDownload the downgrade file of your device model. And copy it into your root directory of your sd card. Then go to recovery mode and choose, 'apply update from external storage'. After downgrading, clear chache and factory reset your device.Tried to downgrade but the file I downloaded does not worked on my asus zenfone LITE L1
Please reply what to do
When we will be getting fota update of Android P?
05-04-2020 09:00 PM
05-05-2020 08:42 AM
subhankarbarua007Yes sir I am pressing volume up and power button simultaneouslyhttps://zentalk.asus.com/en/discussion/comment/77155#Comment_77155
Fastboot ?? Are you pressing volume up and power button ?? For getting into revovery mode, you need to press volume down and power button. And if you see 'no command' error in recovery mode, press volume up and power button simultaneously.
05-07-2020 04:40 AM
justin111🤣🤣🤣🤣🤣https://zentalk.asus.com/en/discussion/27452/android-10-update-not-received-on-asus-max-m2-device
Hello,
Please for the love of god don't Update using the ZIP from the Asus website. The file ruined my phone. I downloaded and copied on the root and then checked for Update. It detected the update package and started install. The phone rebootrd and came to a screen which asked for a password. It should be noted that the phone has no pin, pattern, password or face unlock.
My question is how did Asus put a password on the ZIP file ??
subhankarbarua007Me 2https://zentalk.asus.com/en/discussion/comment/76604#Comment_76604
Sure, I will keep updating 😊
05-14-2020 03:21 AM
