How remove handset symbol my asus max pro m2 ?
Golubhandari
I don't connect earphone but handset symbol are notified in notification bar
Shahed
Tried restarting? Because if you haven't tried that yet please do once , because that's a very minor problem can be solved by restarting the device.
victor010
Zen Master III
Hi, we'd request you follow the below steps:
1. Clear system cache.
2. Try the same under safe mode:
Hold the power button for 5 seconds => When the screen flashes with option => Press & hold power option => You will get an option to restart in safe mode
3. If still you face the issue factory reset your phone after taking a full backup.
